Factory battery charge lead rubbing on drive belt
I have a 2016 SGS and always put it on the battery tender after riding.Factory charge lead is behind left side cover so I have always pulled loose bottom of side cover and grabbed charge lead and when I was done,I tucked charge lead up into cover and snapped it closed. Today after riding,I went to grab lead after pulling bottom of cover loose and had all kinds of sparks.I quickly removed left saddle bag and left cover and found charge lead was almost rubbed through.It took me awhile to figure out what had caused this.When I would push the charge lead back into the cover,it would kink and go around rear vertical frame rail and right under top of drive belt.Factory charge lead is to long and not secured with tie wraps to stop this.I repaired mine and secured it to the vertical rail and left enough to just stick out from under the cover.I would suggest anyone with a Rushmore check this.
It is up to the end user (or dealer) to remove the cable and route it to their preference.
Most dealers do exactly how you found yours.
If the cable is removed and tucked back under the side cover, you need to make sure the cable is secure and contained.
They are zip tied in there pretty tight from the factory.
My14Ultra
2014-2023 Touring Models
26
05-14-2015 06:18 PM
