2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Air ride 2014+ dash switch part #?
Old 04-12-2017, 08:37 AM
bobz74's Avatar
bobz74
bobz74 is offline
I have utilized all my switches on my 2014 street glide without the harness mentioned. First you need to decide on standard or momentary switches depending on what you will be operating. Also Legacy Baggers(facebook) makes some nice stickers.
So for switches 2 thru 6 (starting from left to right) the wires are located under left side cover it is a gray plug. That plug also contains 12v, ign power and ground (so total of 8 wires) if you don't have service manual use test light to identify.
Once you decide what you are using each button for then you will know if you need to wire in a relay ie air ride will need relay, led lights no relay. 2 amps is the cutoff for relay.
If you don't want to cut the plug then go find the female plug that works and pin out your own plug. I decided against that for the ease of swapping switches when I change my mind.
If you want to use switch 1 then you need to locate the Blue/gray wire under the tank and tap that wire.
And yes that is a backup camera on my bike.
Old 04-12-2017, 09:41 AM
Twilighttwinlight's Avatar
Twilighttwinlight
Twilighttwinlight is offline
Stage III
How do you wire in the relay? I guess that's my question and what relay do I buy? Just a small relay from the parts store? Because the harness has a relay attached to it so I can cut the connector off wire in my wires from my dirty air kit? Thanks
Old 04-12-2017, 10:23 AM
bobz74's Avatar
bobz74
bobz74 is offline
Buy the relay and it will show you how to wire. Gets a ground and 12v switch, signal in i.e. From air ride and wire to button.
Old 06-17-2018, 11:35 AM
JMB19's Avatar
JMB19
JMB19 is offline
4th Gear
I want to do this exact setup! from left to right Switch #1 ACC (to power dirty air air ride and love jugs fans) #2 *** UP #3 *** DOWN #4 Center Stand down #5 Center Stand up #6 Air ride safety dump valve. I know this post is over a year old but, can you please advise what to buy and where for switches and maybe some pertinent wiring tips? I have a 14 Street Glide FLHX and only have #2 and #3 ACC switches. #3 currently powers up my fans and air ride. Any help would be greatly appreciated.
Old 10-25-2020, 02:22 PM
Mike Campbell's Avatar
Mike Campbell
Mike Campbell is offline
Stage III
Air ride switches for 2014 and up harley davidson a great product made by Evil Iron Customs. They mount in your factory dash location
Old 10-26-2020, 01:14 PM
Roadking69's Avatar
Roadking69
Roadking69 is online now
That's what I sell and install
Glideiron
04-12-2019 08:32 AM
paullavery
Milwaukee Eight (M8)
04-02-2017 12:06 PM
mpr3369
09-21-2016 07:20 AM
bigfish_Oh
05-04-2015 08:48 AM
dionne51
06-27-2007 01:32 PM
Quick Reply: Air ride 2014+ dash switch part #?
