2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Need Help. Primary/Clutch Removal
Old 12-12-2015 | 04:45 PM
Vernal's Avatar
Vernal
Originally Posted by lp
This isn't hard to do but it takes a little explaining which if you had the shop manual would eliminate having to have someone type it all out.
In short you need a T70 torx, a primary locking tool, a breaker bar and some muscle. Loosen, but don't fully remove it yet.
Then you need to remove that snap ring on the clutch, take out the spacer/bearing etc, and fit whatever the size socket it is that is in there but remember to go backwards as it's reverse thread.
After you've loosened both fasteners you can slide both the comp and clutch out at the same time.
Maybe Vernal (a member) will be kind enough to paste photos of the removal procedures straight from the manual into this thread for you. He's a cool guy like that.
Thanks IP I did one better and sent him a link to a electronic Service Manual someone else posted a few months ago. ✌
Old 12-13-2015 | 03:31 AM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
Let me save you some more aggravation. The clutch hub nut is a left hand thread.
heavypic
13
06-14-2021 05:53 AM
BenRK05
02-21-2014 06:33 PM
lunyty1
07-13-2010 09:11 AM
ANIMAL03
01-06-2010 02:09 PM
harley-jones
12-17-2009 11:30 AM
Quick Reply: Need Help. Primary/Clutch Removal
