Lost the CB antenna....again
Nope! I intentionally lost mine along with the FM antenna the day I bought my bike. But that's not the same.
You know what I'd think of doing if I were in your shoes. The loctite idea suggested might work but it may also interfere with the antenna's effectiveness so what I would consider is this... After installing a new antenna drill a very small diameter (1/16 or less) hole through the antenna base and the mounting stud. Then stick a pin in there so it can't unscrew.
I stopped mine from coming loose by using a "Star" type locking washer from Ace Hardware under both antenna's! Also double wrapped the antenna's with a polishing cloth (so it doesn't mark or chew into the antenna's) and used a pair of pliers to tighten them a little snugger than hand tight.
I've not had that issue, but I've got the shorty antennaes on my bike. I do believe that 2Black1S idea is a good one. Another thought might be to use a thin internally serrated lock washer. Then tighten the Antennae enough to crush the lock washer as close to its exterior non serrated thickness as reasonably possible.
Please do not do this...
A star washer is the right idea.
So now if you would, please tell me how you could determine my knowledge, or lack thereof, relative to CB antennas by my drill and pin suggestion; and also why it's not a plausible solution to the OPs problem.
Keep in mind that I never said that my idea was the only way to solve the problem and the OP must do it my way. I simply stated that it was something I would, and the OP, could consider.
And a big, hearty, sarcastic thank you for your input!
