2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Lost the CB antenna....again
Old 11-26-2015 | 07:36 PM
hbsoldier3's Avatar
hbsoldier3
I just glad I do not use my CB after reading all this
  #32
Old 11-27-2015 | 09:23 AM
yzernie's Avatar
yzernie
Please keep an eye out for my antenna on the 55. Lost it after leaving Blackies!!!!
  #33
Old 11-27-2015 | 09:53 PM
jungleman's Avatar
jungleman
I have drilled a hole and put a set screw in one on my antennas.
A star washer would be easier.
Drilling a hole and pinning the antenna would be hard, but would not ruin the radio. The antenna stub on the HD is the transmitting part. The grounding part is inside of the tourpack. So you actually would not be shorting it out. KD8PTJ
  #34
Old 12-12-2015 | 10:23 PM
yzernie's Avatar
yzernie
HD did a warranty replacement on the antenna and the mounting stud....even though I am outside of the 2 year warranty. They said since it happened once before they would be replacing it with no problem. They did blue Loctite the set screw into the mounting stud this time. Good as new now!!
Charlie Fogg
02-25-2015 07:29 PM
06SGWA
09-01-2014 03:04 PM
LQQK_OUT
Audio Systems
08-26-2013 07:39 AM
lkb307
03-10-2012 04:26 PM
BLUEICE
10-02-2007 11:10 PM
Quick Reply: Lost the CB antenna....again
