Best Pullback Handlebars
Mine are basically 2 up 2 back. There is room to rotate them some. Mine keep my hands behind the fairing and I was able to install them without adding extensions or replacing any cables, just had to clip some zip ties behind the fairing and reroute a few things.
What he said. They fit me perfectly at 5' 6". My hands are between my shoulders and elbows and I can ride all day long on my '14 SGS. Make sure you order the NARROW 2+2's. And they're reasonably priced on top of not needing to extend any cables.
Having owned five trikes, last one a 14 TG, if I was going with 2+2 sweepers, I would go with the narrow ones unless they a very long armed, driving a trike and at full lock would a stretch with the wide ones...just my opinion...check on the TG forum...
Casper, I am looking at a Street Glide and pullback bar options. I had the Harley pullbacks on my Ultra, they were ok. I am 5'10" and a 34 arm length. Do the sweepers put the bars back about 2 inches from stock?
This is from the Khrome Werks site about the narrow 2+2 sweepers:
Features: By customer request - our popular 1" Sweeper handlebars are now available in a Narrow version. Grip to grip is 31-3/8"; three inches narrower than our current bagger Sweeper bars. Compared to the 2014 factory handlebar this bar provides 2-7/16" additional pullback and adds 2-11/16" in height. Grip angle is rotated slightly forward (3-1/2 degrees) for more comfort. Diamond knurls, elliptical center slot, drilled dimples with right grip notched for ETC. May be used on 1997-2007 models without ETC for internal wiring. See P/N 300100 for our ETC Grip Extension for non-ETC applications. NOTE: One piece upper riser clamp (H-D 55918-08) must be used when installing bars with center elliptical slot on pre-2008 baggers.
These may be the bars I need as well.
