Rushmore Road King
My '14 King has the same front end but I went the 30mm Ohlins cartridge route from Howard at MotorcycleMetal. Don't know if it can get better than that but I have no experience with the brand you are referring to.
So no problem with fitment on your Rushmore King using the Ohlins? That's the issue right now with the Progressive and Legend mono tubes; nobody seems to know if they'll fit the Rushmore King. They say the nacelle gets in the way.......
Any further thoughts on this would be greatly appreciated.
Lobo
Lobo
Lobo
Lobo
The nacelle is an issue and not at the same time. My nacelle is completely stock right now and the forks are obviously in. What the nacelle does, no matter what brand you go with, is cover up any adjustment you may want to later do. I plan to remove my nacelle and create an opening that allows me to get to the preload/rebound/compression adjustment and then cover those areas with plugs thus allowing access anytime I want. All my initial adjustment was done with the headlight and nacelle off.
Here is a pic of the top of my forks before putting them in. Don't have any shots after because it doesn't look any different than stock. I also have the Ohlin #6's in the rear.
