2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
2015 Street Glide Special and Arlen Ness Stabilizer
Old 11-06-2015 | 10:45 PM
Milty's Avatar
Milty
Default 2015 Street Glide Special and Arlen Ness Stabilizer
Well a 2 beer job turned into me getting my *** handed to me trying to bolt this pos in place of the stocker stabilizer. Eye to eye measures the same but it just don't line up. I am now in snap mode, I think I've tried everything. Had a bunch of other chit to do but I'm bagged out. Part number is right for a 2014-2015. Has anyone installed this little gem successfully?
Attached Thumbnails 2015 Street Glide Special and Arlen Ness Stabilizer-image.jpeg
Old 11-07-2015 | 09:56 AM
smitty901's Avatar
smitty901
So why does a 2104 Sg need a ness stabilizer?
Old 11-07-2015 | 10:34 AM
Milty's Avatar
Milty
Same reason my 2015 Street Glide Special needs any after market parts, to look cool of course.
Old 11-07-2015 | 10:47 AM
Gwaxley's Avatar
Gwaxley
Where there's a will there's away, snapback and look at it. It's hitting something your not seeing or a motormount needs temperarly loosened
Old 11-07-2015 | 10:50 AM
db252's Avatar
db252
I do have one as well but don't remember any problems. I also installed it in reverse direction so that the logo is not visible. Both bolts where started loosely which I'm sure you are doing. I also did it while on the kick stand but I can't see that helping over being on a rack if you are doing it that way. Be patient; it will happen.
Old 11-07-2015 | 11:44 AM
Milty's Avatar
Milty
I don't know? It just looks like a big bind. I have the front mounts on the motor loose. I bolted the first couple threads on the right side of the bike with the stabilizer but any configuration I turn the stabilizer to its out about 1/4". $&@$ you Arlen!
Old 11-07-2015 | 12:35 PM
Led Sled's Avatar
Led Sled
I had the same problem. I put a bolt in one end and physically pushed the engine to line it up. Had the wife start the other bolt while I held the engine in place.
Old 11-07-2015 | 01:21 PM
Milty's Avatar
Milty
Ok Thanks.
Old 11-07-2015 | 02:53 PM
db252's Avatar
db252
It will happen and take your time. If anything, loosen the bolts on the front bracket to give you a little play but don't remove them.
Old 11-07-2015 | 10:12 PM
Milty's Avatar
Milty
Got 'er, thank you for the tips. With front mounts loose, one good pull on the front cylinder seated the bolt. Can you see it? Lol
Quick Reply: 2015 Street Glide Special and Arlen Ness Stabilizer
