2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Checking air pressure
Old 10-13-2015, 10:31 AM
BillJ's Avatar
BillJ
BillJ is offline
Originally Posted by 2014sgs
Stupid question. I have the same tire guage and I want to switch to the small brass chuck. Of course the thing came with no instructions. How do you remove the "stock" chuck? I played around with it for a while but could not figure out where to remove....
Thanks
The chuck that comes on the end of the hose is threaded and it will come off, you will have to put some elbow grease into but it does unscrew.
I thought at first how in the heck do you change the chuck but I just put some muscle into it and the chuck did unscrew.
You will likely have to use a rag and a pair of pliers on the knurled end on the hose side so you don't damage it and use the proper size wrench on the chuck it come attached with. It will take some force but it will unscrew.
Old 10-13-2015, 11:04 AM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
I use one of these... and as a bonus, it has a tread depth gauge.
Old 10-13-2015, 11:30 AM
EricD10563's Avatar
EricD10563
EricD10563 is offline
Originally Posted by hotsun
HD makes a valve stem extension. It screws on the tires valve stem and the you can check pressure and add air if needed. Much easier than trying to get an of the fittings I have on the tire.
Cheap investment and it works well.
http://www.harley-davidson.com/store...stem-extension
Old 10-13-2015, 12:26 PM
indiggio's Avatar
indiggio
indiggio is offline
Old 10-13-2015, 01:25 PM
nerider2's Avatar
nerider2
nerider2 is offline
Old 10-13-2015, 02:39 PM
2014sgs's Avatar
2014sgs
2014sgs is offline
Thanks!
Old 10-13-2015, 05:10 PM
Seventy4blazer's Avatar
Seventy4blazer
Seventy4blazer is offline
It is annoying, but personally I don't see it as hard... I am not sure how else that it could be done since they already put the stem off to the side making it easier....
guess you could spring for a new bike with TPMS...?
Old 10-13-2015, 05:51 PM
streetglide44's Avatar
streetglide44
streetglide44 is offline
Default I bought this one for my Jeep and Bikes
Cycle Gear. $29.99 measures to the tenths.
Old 10-13-2015, 09:15 PM
tenn volunteer's Avatar
tenn volunteer
tenn volunteer is online now
Veteran: Marine Corp
Good luck with the stuff from Cycle Gear. That Chinese gauge measured 10 pounds off for me; it went right back to Cycle Gear.
Old 10-13-2015, 09:59 PM
Udawg's Avatar
Udawg
Udawg is offline
A friend gave me a kit that included a gauge and I love it. It is inexpensive but works like a charm. It clips on the stem so you don't have to hold it and doesn't leak. Then you take your time with the trigger to fill it and it shows the pressure as you fill it. If you get a little too much in just press the black button and let a little out.
http://www.grizzly.com/products/h5530
Attached Thumbnails Checking air pressure-005.jpg   Checking air pressure-006.jpg   Checking air pressure-007.jpg   Checking air pressure-008.jpg
Quick Reply: Checking air pressure
