Checking air pressure
It's NOT that difficult. Front tire, check and adjust air pressure while valve is position to the front. Rear tire, valve should positioned to the bottom. I use a standard air chuck from my air compressor and a motion pro digital air gauge. Tires should be checked weekly.
2015 is by far easier than 2007, 2009 or 2011.
This is a good quality item, makes filling and checking your tire very easy.
Get from Broadtracker for 20 percent off.
http://www.harley-davidson.com/store...ompressor-tool
Checked it against my digital and they both read 40 rear and 36 front.
Easy fill and check, insert it straight in and the wand has a side port.
I did the 90 degree stems on my 2011 and regretted it. After I put the 90 degrees stems on, I had to use two hands to check and adjust air to support the valve stem. I'll never do that again.
Stupid question. I have the same tire guage and I want to switch to the small brass chuck. Of course the thing came with no instructions. How do you remove the "stock" chuck? I played around with it for a while but could not figure out where to remove....
Thanks
