2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
LED fog lights are the worth it
Old 10-11-2015, 04:08 PM
timidones's Avatar
timidones
timidones is offline
Default LED fog lights are the worth it
I've been looking at the new LED bullet fog lights for the 15 limited. At close to $600 bucks for the lights, wiring, switch and mounting brackets, I'm wondering if its worth the cost.
Has anyone installed these and was it that kind of money?
Old 10-11-2015, 04:44 PM
mstrobes's Avatar
mstrobes
mstrobes is offline
Yes, I put them on. they sure do help for the corners. i turn the passing lights outward a little too.
Old 10-11-2015, 10:58 PM
04ctd's Avatar
04ctd
04ctd is offline
need pics & linkie?
i can't see crap in turns with the OEM lights
Old 10-12-2015, 12:20 AM
58sniper's Avatar
58sniper
58sniper is offline
If they're the daymaker fog lights, I LOVE them. They really cast more light. I wired mine to a switch on the dash on my '14 FLHTK.
Between those, the daymaker spots and headlight, the CD Dynamic Ringz and the CD white LED fender tip, you can't miss my bike.
Old 10-12-2015, 09:46 AM
SlowRain's Avatar
SlowRain
SlowRain is offline
Installed on mine as well. I didn't rig an additional switch, instead just used the cable that splices into the passing lamp switch so I can flip them on and off using that if I choose to. I aimed mine up just a hair above level to the ground and they do make a huge different in the corners. Toughest part of the install was getting them adjusted to the way I wanted them to illuminate and getting all the cabling secured. The splice cable that you would use if you have a bike with passing lamps is WAY to long!
Old 10-12-2015, 09:49 AM
58sniper's Avatar
58sniper
58sniper is offline
That's how my dealership originally did mine, even though I asked for a separate switch. I didn't like the "all or nothing" approach, and split them out while I was wiring up something else an and had things torn down.
Old 10-12-2015, 09:53 AM
bigrobtemp's Avatar
bigrobtemp
bigrobtemp is offline
Here is my limited. Harley daymakers, cd ringz, cd fender light. They see me coming.
Old 10-12-2015, 07:42 PM
68 XLCH's Avatar
68 XLCH
68 XLCH is offline
HD Passing Lights, CD turn signals
Old 10-12-2015, 08:35 PM
zoozoo's Avatar
zoozoo
zoozoo is offline
Received 31,609 Likes on 8,454 Posts
Is that fender light plug and play like the turn signals?
Old 10-12-2015, 08:46 PM
58sniper's Avatar
58sniper
58sniper is offline
Yep. CD front and rear fender tip lights are both plug and play.
Quick Reply: LED fog lights are the worth it
