Clutch adjustment with hydronic clutch
Have you noticed that clank-bang noise and maybe even a slight forward lurch when going from neutral to first? That's also gone on mine - and when the bike's cold, it goes into first silently!
You're on the right track about the clutch dragging, but in this case it's due to the banjo-string-tight chain binding up the freewheel bearing in the clutch and trying to drive the tranny through that bearing.
I found the chain on mine to be so tight, when the bike was stone-cold and before I removed the (IMO, total POS) auto-tensioner for its one-way trip to the dumpster, that it didn't deflect more than about 1/16" when I put about ten pounds of pressure on it between the sprockets - and it gets considerably TIGHTER once the bike's at op temp.
I really don't see how the bearings and other components in the primary can take that kind of abuse for any length of time at all. They must be damn tough is all I can say.
I also went with Redline in the primary and tranny, but I don't know if that had any additional effect or not.
It's not a super-difficult install for anyone with moderate mechanical knowledge and skills, the correct tools, the factory service manual and the ability to carefully read and follow directions.
Anyway, best of luck with your new ride, and stay safe.
Also, I'm not affiliated with Baker Inc. in any way, just a big fan of this particular product!
JP
Leave the heel-shifter ON. I've changed the fluids in my clutch and trans very 5000miles (yeah, I know...excessive, waste of money, etc...but I don't care cuz I ride LOTS and OFTEN on long uninterrupted trip miles and in stop-go lane-splitting threading the needle commuter traffic ) It didn't make any difference to me what fluid brand/type I used in those two holes...what made a BIG difference was where I leveled the heel lever, the accumulated miles, and how I finessed my heel tap after I found 1st gear...and I came from the sportbike and dual-sport crowd I LOVE the way my heel/toe shifter works on my RGS
You can get your service manual here for only $19 if you don't mind a digital version, works great on an iPad with the GoodReader app. I haven't seen the 2016 manuals uploaded yet. http://www.motorcycle-manual-downloa...roducts_id=241
