2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Fob don't work every time
Old 09-21-2015, 08:31 AM
billyjp's Avatar
billyjp
billyjp is offline
Default Fob don't work every time
Fob don't work every time have to have to put pin# in to start bike, have 2 fobs both doing same, tried new battery, don't know if its warranty item, will take it in tomorrow be hard to find if all is working when you get there, anybody had this, what was the fix ?
Thanks Billy
2014 Limited
Old 09-21-2015, 10:32 AM
tt_ksu's Avatar
tt_ksu
tt_ksu is offline
Do you happen to have the fob in the same pocket as your phone when it happens? If so, put them in different pockets to see if the issue remains. Mine interferes with the fob.
Old 09-21-2015, 10:52 AM
Cool Inferno's Avatar
Cool Inferno
Cool Inferno is offline
If you have the HD siren with your security system, check the antenna wire that connects to the siren. Should be a thin black wire. My understanding is that it can not ground against any metal parts as per the installation instructions.
Old 09-21-2015, 11:54 AM
billyjp's Avatar
billyjp
billyjp is offline
No phone no siren, thanks for reply.
Old 09-21-2015, 12:20 PM
Smokey Stover's Avatar
Smokey Stover
Smokey Stover is offline
If you park it near an auto with a similar hands free RF signal it can happen. Rarely, I'll just roll it back a few feet.
Old 09-21-2015, 02:48 PM
wethead103's Avatar
wethead103
wethead103 is offline
Just cycle your ignition switch once or twice, it should work then. Mine does the same thing of I've moved the bike around without starting it. Or if I played with the infotainment system with the ign. on acc. Good luck!
Old 09-21-2015, 04:58 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
Have you tried using the second fob, that came with the Bike ? Plus all of the above suggestions.
Old 09-21-2015, 06:02 PM
Cool Inferno
Just checked and the security system without the siren has an antenna also but its not a wire. Take a look at the antenna and see if the connection is good. The antenna is part #3
http://www.harley-davidson.com/app-c...ts/-J04082.PDF
Old 09-21-2015, 07:44 PM
Cobra231's Avatar
Cobra231
Cobra231 is offline
I had the same thing happen with my brand new bike, switched to my other fob and hasn't happened since. I actually just started down the road one day with the original fob and it displayed that I didn't have the fob as I was riding.
Old 09-21-2015, 07:50 PM
zoozoo's Avatar
zoozoo
zoozoo is offline
Received 31,592 Likes on 8,452 Posts
Thanks Billy
2014 Limited
Should be under warranty
Quick Reply: Fob don't work every time
