2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Radio volume fluctuating
Old 09-12-2015, 10:34 AM
dzlpwr's Avatar
dzlpwr
dzlpwr is offline
Originally Posted by Brewmany
Yeah that nav prompts drove me nuts till I figured out what I did. Finally dawned on my that the only time I had the fade out thing happening was when I was moving. I'd listen to the music while parked to try and figure out the problem- no cutout. Once I was rolling, cut out. Finally the light went on and I got it.
Would it cut out completely or just get quieter? My issue is not the music cutting out completely. the volume just
Randomly bounces around, even when I am not using nav.
Old 09-12-2015, 10:54 AM
davesvn007's Avatar
davesvn007
davesvn007 is offline
Also check your Speed Volume setting (Home -> Setup -> Audio Setup). This setting affects the volume based on your speed. Maybe it's acting up... you can change it to it's lowest setting to turn it off. Then see if the volume still cuts out.
Old 09-12-2015, 01:06 PM
dzlpwr's Avatar
dzlpwr
dzlpwr is offline
It does it no matter what setting the AVC is on. I'm going to try messing with the weather band and see if maybe that is doing it. It's raining here so I can't test it today sadly.
Old 09-12-2015, 06:23 PM
zoozoo's Avatar
zoozoo
zoozoo is offline
Received 31,473 Likes on 8,426 Posts
dzlpwr, if you can't fix your issue with setting adjustments go to your dealer and tell them to fix it. It's under warranty. What you're describing is not suppose to happen and don't let them tell you it's normal because it's not!
Old 09-12-2015, 07:14 PM
dzlpwr's Avatar
dzlpwr
dzlpwr is offline
That's the plan. I was just assuming they will say it's normal since that's how it usually goes. If the settings I messed with didn't do anything after riding tomorrow im going to mention it when I take it for the 1k service.
Old 09-12-2015, 07:37 PM
scott_db's Avatar
scott_db
scott_db is offline
I have the same issue, but only when I turn the volume up like 3/4.
Old 09-12-2015, 08:13 PM
dzlpwr's Avatar
dzlpwr
dzlpwr is offline
Yes, mine too I only notice it getting quieter and louder when the volume is turned up high and at high speed.
Old 09-13-2015, 04:21 AM
apxpred's Avatar
apxpred
apxpred is offline
I'm in the same boat, annoying as hell.
Old 09-13-2015, 05:04 AM
jpalm's Avatar
jpalm
jpalm is offline
Probably one of two things. The DSP in the head unit causes fluctuations in the volume at different speeds. This is probably even more noticeable with high quality components unless you have the unit flashed.
I've noticed that when I have my iPhone plugged into it that having programs running in the background sometimes causes volume problems. Also, the momentary dips in volume are caused by messages or notifications popping up on the phone. Obviously this only applies when I'm playing music through it.
Old 09-13-2015, 02:52 PM
dzlpwr's Avatar
dzlpwr
dzlpwr is offline
From what I'm reading, the DSP Seems like it's the culprit. Can it be re flashed to get rid of this? Without adding an amp? If so, what flash do I need to ask my tech to install?
Quick Reply: Radio volume fluctuating
