Primary plug magnet full of it
Changed my oil in the transmission and the primary for the "miracle" Redline product the other day. Heard and read so much good about this brand that I decided to give it a shot, even though I just changed all three holes. When I dumped the still very fresh SYN3 I had in my tranny, it looked as good as new. The plug had no residue collected on the magnet. When I unscrewed the plug of the primary it was a different story. The plug was loaded with metal ground and the synthetic Mobil 1 V-Twin I had in there was dark. You could literally see fine metal particles shimmering in it. That's why I post this thread. I am quite concerned about my observation and would like to hear from you guys what you encountered when you did the second primary oil change. I changed the primary the first time at around 300 miles then at 1K, as recommended and now at approx. 3K. So the oil has been used for about two thousand miles. Again, the tranny was like new, the primary pretty dark in comparison. What you think? Do I have a reason to contact my dealer ship?
Did you happen to take a pic?
Almost every drain plug I have ever pulled, either from my 96 or my 103's, has had a little coating of gray almost graphite looking material on it. I just did a friends 3 fluid change 1000 mile service and his had the same thing. I chalk it up to normal.
Edit....the more I think about it, I believe the primary comes out with the most material on it.
No, it didn't have "slivers" or "hairs" on it, but was pretty "loaded" with black metallic ground. I didn't take a photo, but wiped it off with a paper towel and kept that for "show and tell" at the dealer ship. I also kept the oil for the same reason. My first and second oil change did not nearly show that much residue on the magnet.
