2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
What is the clear coating HD uses on the lower front fork legs?
Old 07-06-2015 | 05:08 PM
OldMike's Avatar
OldMike
Originally Posted by HogPilot54
Thanks for all the reply's. Not looking to chrome the lowers or powder coat them. Still experimenting with different coatings that will blend in with the rest of the lower leg, but have yet to come up with anything that works. Still looking for input from anyone who knows what will work. The reflectors are not going back on. There is enough lighting on my bike to be seen from every angle at night BUT... if someone knows of a WHITE reflector with the same shape as the stock yellow ones, I would be interested in those.
3M reflective tape, you can get it in different widths or cut to any size you like.
Old 07-06-2015 | 05:22 PM
jpooch00's Avatar
jpooch00
I wonder if that coating is just clear powder coat? I'll bet that's what it is.
Old 07-06-2015 | 06:35 PM
HogPilot54's Avatar
HogPilot54
Well... if it is I'm screwed. Not going to spend that kind of money. Guess I'd just have to re-install the reflectors. I know Kuryakyn sells those lower leg accent covers because I had them on my 09 Road King. But after checking their site, they don't make them for the 14's and above... yet. Those would cover up the area.
Old 07-07-2015 | 12:23 AM
HogPilot54's Avatar
HogPilot54
I think I found the fix (albeit a cover-up). I ordered these white saddlebag reflectors off Ebay. They're smaller than the stock amber reflectors I removed from the lower fork legs but I think they will cover up the blemish just fine. Since I'm going all white/clear on the front end with the lights, these should work nicely.
http://www.ebay.com/itm/301657359635...%3AMEBIDX%3AIT
Old 06-16-2017 | 05:16 PM
TheOrg's Avatar
TheOrg
Why not cover up with stick on white reflector material, its tuff stuff and you can cut it to suit
Westash
Powdercoat & Paint
05-23-2013 10:16 AM
Davino
12-06-2012 05:49 AM
dortiz
09-22-2011 07:30 PM
bowhnter7
12-16-2007 07:20 AM
MAX EVO
10-04-2006 01:00 AM
Quick Reply: What is the clear coating HD uses on the lower front fork legs?
