2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
tour pack for a street glide
Old 04-09-2016 | 08:48 AM
DanHappy's Avatar
DanHappy
Originally Posted by elb62
Just picked up my tour PAK and checked the two up detachable mounting rack on the 4-point docking before I mount to tour PAK. The rear of the rack looks to be to narrow for the 4-point docking. Dealer installed the 4-point and I’m not sure if the rear mount chrome spacers are in the right positions. Should the small one be on the inside and thicker one on the out side? Looking at the HD parts manual it looks like thick inside and small outside. What am I missing?
DO whatever works to make the mount work. I had to space the black part out a little more to get my mount
To work.
  #62
Old 04-09-2016 | 11:01 AM
elb62's Avatar
elb62
To work.
Got it. Just real tight.
  #63
Old 04-09-2016 | 11:02 AM
elb62's Avatar
elb62
  #64
Old 04-09-2016 | 11:22 AM
DanHappy's Avatar
DanHappy
Cool. Without spacing one out, it worked. I wanted it out a little more so, when putting it on, I didn't want it too tight that I might pop off and scratch the fender.
  #65
Old 04-09-2016 | 01:45 PM
GlidingJoe's Avatar
GlidingJoe
Parts List
Chopped Tour Pak 92200073DXX
SOLO Tour Pak Rack 53000225
Kit Spacer/Tour Pak 53000461
T-Pak Lock Kit 9000030
Chopped Tour Pak Pad 52300359
Tour Pak Spolier 557200086DYO
LED Spoiler Light 53000238
Extension Wire harness 69201157
This is for the solo set-up
Originally Posted by Don Don
I have the exact same cycle and it appears you have it set up for 1 up with the option for 2 up riding, depending on were you position the tour....
could you PM me the parts listing you had for this set up, I want mine to look exactly like yours.....thanks in advance
oh and did you do the wiring yourself, and got any more pics to share
  #66
Old 04-09-2016 | 09:18 PM
Dallas Ford's Avatar
Dallas Ford
I went a whole different route.
  #67
Old 04-09-2016 | 09:23 PM
Blue Tick's Avatar
Blue Tick
What have you guys used for lighting with your tour packs? I've got mine all setup/installed and now looking at lighting options for it. I'm wanting to light the back end of the bike up a bit more.
  #68
Old 04-09-2016 | 11:44 PM
bigh8840's Avatar
bigh8840
I just put the chopped pak on mine with no lighting. I'm really looking forward to my ext bags to tie it all together!!
I used the Mustang pad instead of HD. Not sure if I like how hick it is or not.
  #69
Old 04-10-2016 | 12:44 PM
elb62's Avatar
elb62
I put my wall mount up for the tour PAK today.
  #70
Old 04-10-2016 | 12:56 PM
DanHappy's Avatar
DanHappy
What mount did you use? Thinking mounting mine as well.
Quick Reply: tour pack for a street glide
