Streetglide fender on a Limited pics
I'm looking for some pictures of a Limited with a Streetglide fender that shows the area under the tourpak. The streetglide rear fender moves the license plate from under the tourpak to below the turnsignals on the fender.
I bought a complete take off streetglide fender in my color. This will be a simple bolt on without having to paint, under $350. I was going to leave the license plate mounted high under the tourpak, ending up with a clean fender below the turnsignals. But Harley changed the fenders to have a hole for the wiring under the license plate mount below the turnsignals.....either I mount the lisense plate low or try to figure out a way to plug the hole.
For me, I used Custom Dynamics LED turnsignals and tri-light, with the Street Glide rear fender wiring harness and it was plug and play.
I was surprised how easy it was to swap out the fenders, I didn't have remove the rear tire. I had it on the bike in about 3 hours, way easier than when I did my 2007 Ultra.
I was looking for pics of the area under the tour pak to determine what it would look like with the fixed Limited tour pak bracket, without a license plate. I have no plans to ever remove this tour pak and didn't want to use the detach kit.
What I did do was modify the limited bracket by milling off most of the license plate mounting surface to clean it up and show more rear fender.
PHAT A$$
04-30-2009 11:07 AM
