2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Help with Daymaker Foglight install on 2015 RGS
Old 06-25-2015 | 10:04 PM
DeadBirdDog's Avatar
DeadBirdDog
Default Help with Daymaker Foglight install on 2015 RGS
Does anyone have a clue where the "Four-way turn signal lamp connector (31) is under the fairing? I have the lights, harness, brackets and AUX switches installed and powered but for the life of me I can't figure out where to plug in the wiring harness to the bike itself. I'm starting to wonder if this can even be done off of the AUX switches. Nothing even remotely looks compatible under the fairing to snap-splice the harness into. The instructions call for the removal of the outer fairing and to connect the foglight wiring harness 69201109 into the
Four-way turn signal lamp connector (31). Connecting to either of the signal lamp wiring connectors doesn't work. I've tried every connector under the fairing that would fit and nothing works. The AUX switch wiring runs back under the tank to the two unconnected AUX busses under the seat. The wiring harnesses do not match up.
This post talked about the same issue but there was no follow-up
https://www.hdforums.com/forum/new-r...mp-wiring.html
What gives? Do I just need to come up with my own molex connector to the bus under the seat? The MC instructions for this stink on ice.
Old 06-26-2015 | 02:47 AM
Hammz's Avatar
Hammz
The harness plugs into the accessories connector under the left side cover.
Old 06-26-2015 | 03:10 AM
DeadBirdDog
I still don't see anything under the cover that's even close to a match to plug this harness in.
Attached Thumbnails Help with Daymaker Foglight install on 2015 RGS-2015-06-26-04.04.46.jpg
Old 06-26-2015 | 06:17 AM
d-streetglidr's Avatar
d-streetglidr
From: South Carolina-First to secede and hopefully the next.
I could be wrong, but I believe you just need to remove the rubber plug from this connector.
Old 06-26-2015 | 11:16 AM
DeadBirdDog
Nah...it's not even close to matching up. I'm starting to think that I'm going to have to hard wire it myself. For what these things cost this is a disgrace.
Old 06-26-2015 | 11:29 AM
Hammz's Avatar
Hammz
It's actually the white connector above this grey connector. I think the OP doesn't have the correct adapter harness.
This is the adapter harness needed.
Old 06-26-2015 | 11:37 AM
DeadBirdDog
This is the one I have that fits the Daymakers:
http://www.harley-davidson.com/store...11-69201109--1
Old 06-26-2015 | 11:52 AM
Hammz's Avatar
Hammz
Mine was installed using this adapter. http://www.harley-davidson.com/store...ion-update-kit
I think the universal wiring kit was used because I didn't want it connected to my driving lamps. It did require some additional pins inserted. It uses a latching switch installed in the middle position of the left side console switch assembly. No BCM module programming was required.
Hope this helps.
Old 06-26-2015 | 12:55 PM
DeadBirdDog
I spoke with the dealer today and they really had no idea either. They've never installed these lights on a 2015 RGS. They were of the opinion the the BCM might need to be programmed to accept the lights. What nonsense. I think I'll buy that harness you used and just hard-wire it into the AUX connector under the seat. I know that will work.
Attached Thumbnails Help with Daymaker Foglight install on 2015 RGS-2015-06-26-02.03.48.jpg
Old 06-26-2015 | 02:44 PM
DeadBirdDog
Just came back from my local dealer who donated free diagnosis time because they wanted to know what they deal with these was as well. A BCM flash doesn't work. The only way according to them to make it work is to manually splice the foglight harness into the accessory leads under the seat. This is NOT plug and play as advertised. I'll write it all up with pictures next week.
Quick Reply: Help with Daymaker Foglight install on 2015 RGS
