2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
What cam would you recommend?
Old 06-13-2015 | 05:51 PM
WG2011's Avatar
WG2011
Default What cam would you recommend?
Looking into changing cams, I do a fair amount of two up riding and like the mid range tq. I had the tw-222 on a wide glide which was more of a bagger style cam but I liked it. Thinking I would maybe want a bit more mid range than that cam and also heard it's very close to the Rushmore cam anyway. What are people using and what you you recommend? Thanks!
Old 06-13-2015 | 06:15 PM
desertwolf's Avatar
desertwolf
If you want more than a 222, I'd go with the 777. Does evrything the 555 does only better.
Old 06-13-2015 | 07:32 PM
OldPhat's Avatar
OldPhat
Se-204
Old 06-13-2015 | 07:39 PM
zeke383's Avatar
zeke383
Originally Posted by OldPhat
Se 204
Yup, just put a set in my buddy's 14 SGS. He couldn't be happier. His Road King had Hillside heads and a Woods (I believe) 5-6 cam so he has felt performance before.
Old 06-14-2015 | 07:49 AM
WG2011's Avatar
WG2011
This cam works well with stock compression too? Looking to just do a bolt in cam without any issues or extra work.
Old 06-14-2015 | 08:27 AM
lp's Avatar
lp
Se 204
+2 Great cam that uses all stock parts.
Old 06-14-2015 | 08:29 AM
WG2011's Avatar
WG2011
So the se204 how would that compare to say the Andrews 57h?
Old 06-14-2015 | 08:50 AM
Bikerscum's Avatar
Bikerscum
I'm going with the 57h, gathering bits now. The curves look good for a bagger, and a couple of tube tube dyno videos show good results on a stage 1.
Old 06-14-2015 | 10:14 AM
WG2011's Avatar
WG2011
I too like the looks of the 57h curves and numbers
Old 06-14-2015 | 11:08 AM
OldPhat's Avatar
OldPhat
A good rule to fallow is, what ever cam you think you need take the cam one step down
from that one. Don't over cam your engine, and take into account how you normally
ride the Bike. Good luck on your choice of cams.
Quick Reply: What cam would you recommend?
