Putting new cam in '15 Limited Low, do I need...
If you are installing a cam that is not the same base circle of your stock cam you're going to need adjustable or perfect fit push rods made for that application.
Yes, on the inner cam bearings... always. They are really cheap.
If you don't have the tool, do a search in the classified section. Couple of guys rent them for 25-50 bucks.
Which cam did you choose?
57 is a good stick....from your stage 1 with the Rushmore cam you may feel it to be a little soft on the bottom...to really optimize the 57 head work & a compression bump would be ideal...& then I would go to the 54, better driveabilty IMO... Andrews 48 would be the closest "bolt in" comparison to the Rushmore cam plus carry a little further to the right... All that said,,, a great tune is key which ever you decide.
blair
03-06-2011 09:32 AM
