2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
KST 10" Mayhem bars installed on 14 Street glide special.
Old 06-05-2015, 09:04 PM
harticat's Avatar
harticat
harticat is offline
4th Gear
Default KST 10" Mayhem bars installed on 14 Street glide special.
I just installed the KST 10" bars on my 14 SGS and I like them. A huge thanks to
bpd138 and his walk through install. You won't need a book with his help. The only things I would add are:
Get the Namz control wire extensions. I got the 8" and they just barely reach.
Before you take the pins out of the plug of the TBW plug, cut the protective covering back some so you have more play in the wires.
When removing the ignition switch cover, move the switch all the way to accessory setting so it's flat. This makes space to remove the cover.
Not a bad job and we'll worth the savings!
Old 06-05-2015, 09:43 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
A picture is worth a thousand words
Old 06-08-2015, 09:44 PM
harticat's Avatar
harticat
harticat is offline
4th Gear
Default Photos
Here is a photo
Attached Thumbnails KST 10" Mayhem bars installed on 14 Street glide special.-image.jpg
Old 06-08-2015, 10:48 PM
NWGlide's Avatar
NWGlide
NWGlide is offline
I really like those. I know most people here say "go big" when it comes to bars, but riding up here in the NW, I like a little wind protection. Were these back ordered or did they arrive pretty quick after you ordered them?
Old 06-09-2015, 04:51 PM
Placas's Avatar
Placas
Placas is offline
6th Gear
Thumbs up
Installed the same bars and I love them so much better than stock as soon as I can I'll post a pic.
Old 06-09-2015, 08:47 PM
Big_Black's Avatar
Big_Black
Big_Black is offline
Damn I want my bars now. Some say you dont need to do anything with the wires and you and others say you need extensions. Is it just the way they are routed?
Old 06-09-2015, 09:23 PM
jdunn01's Avatar
jdunn01
jdunn01 is offline
Originally Posted by harticat
Here is a photo
Questions. Im a shorter rider of a 14 SGS (5-8). How much additional pull back did it give vs. stock. I need about 2" to be really comfortable. And how much clearance do you have between the bars and the tank at full lock?
Thank Jim
Old 06-09-2015, 09:24 PM
Placas's Avatar
Placas
Placas is offline
6th Gear
I had my local indie shop do it. They extended the wires and changed the clutch cable. If not it would have been to stretched for my taste and lessens the chance of anything going wrong. Since stock bars are 8 inch I think they went plus 4 or 8 on the wires and clutch cable. You could go with the namz extensions.
Old 06-09-2015, 09:28 PM
Placas's Avatar
Placas
Placas is offline
6th Gear
Thumbs up
@NWGLIDE I ordered mine directly from KST got them for $215.00 included 3 or 4 day shipping
Old 06-09-2015, 09:38 PM
Placas's Avatar
Placas
Placas is offline
6th Gear
@Jim the plenty of clearance. Your other question I wouldn't know but you can always move the bars back from the fairing I'm 5'11 with long arms. If you get them play around with them at different angles.
Quick Reply: KST 10" Mayhem bars installed on 14 Street glide special.
