2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
FM 107" kit with SE CNC Ported heads?
Old 05-31-2015, 08:30 PM
Wghussey's Avatar
Wghussey
Wghussey is offline
Default FM 107" kit with SE CNC Ported heads?
Well I was considering an SE Stage IV kit for my SGS, then got to thinking since I have to pull the jugs and change the pistons, why not go up to the FM 107" and the Woods 555.
I am currious how well the 107" FM pistons would work with the CNC heads? The FM pistons look like flat tops and the SE pistons used with those heads in the kit are flat tops also. So At this point iit would be more of a combined type of kit.
I really want to stomp my buddies 110" CVO with a stage III and 259e cam.
Old 05-31-2015, 08:52 PM
fattybob's Avatar
fattybob
fattybob is offline
I would ask Jaime at FM for his opinion. He would know for sure if your combination will work.
Old 06-01-2015, 05:24 AM
Tn.Heritage's Avatar
Tn.Heritage
Tn.Heritage is offline
Jamie sells a level B Head with his kit that teamed up with the woods 555 cams should stomp that 110 no problem !!
Old 06-01-2015, 08:09 AM
fattybob's Avatar
fattybob
fattybob is offline
I don't know which cam would be the best for an HD Touring bike, but my dyna has the FM 107 kit, woods 777 cams with Level B heads and larger injectors. With 120 TQ it takes off like a rocket and pulls to the limit. Awesome combo!
Really, FM is a leader in research and testing and Jaime has probably seen every combination possible.
Old 07-21-2016, 07:36 AM
bedelman10's Avatar
bedelman10
bedelman10 is offline
My good friend and riding partner put them on his 2012 with woods 777 cams and cp 10.25:1 flat top pistons in the 107 jugs that he had bored, with a tts tuner and everything else bone stock he made 110 horse and 130 tq.
Old 07-21-2016, 07:37 AM
bedelman10's Avatar
bedelman10
oh and i forgot to add, those 110s are not that impressive, i would imagine that the build i just described would run circles around that cvo
Old 07-21-2016, 09:55 AM
wolf1340's Avatar
wolf1340
wolf1340 is offline
I agree 100%. I just sold a 2012 CVO 110" SG. The build listed should easily run away from a 110". I was very disappointed in the 110".
Old 07-21-2016, 11:45 AM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,407 Likes on 1,593 Posts
Yeah just use Jamie's heads that are setup for that combo. It will stop the **** out of the 110.
Old 07-21-2016, 01:43 PM
kustom78's Avatar
kustom78
kustom78 is offline
HA my uncle just bought a new CVO road glide, now I'm looking to upgrade to a 107 and stomp him. I'm looking at the revolution kit though with the heads and TB sent out and 777 cams.
Old 07-21-2016, 02:34 PM
jt metal's Avatar
jt metal
jt metal is offline
My buddy just did a cam & exhaust swap on his SG CVO 110". He makes 1h/p & 2torque more than my numbers. I was surprised.
I've seen guys pull 120/120 out of a 103". I just don't see how? Happy dyno perhaps?
So to be safe, I'd do the 107" with all the goodies. That will mess him up. But when your guys done adding up the bill, maybe a 120" would be more cost effective than you think. Don't forget, you can sell your 103" for $2g to help the cause.
And the 120" would be in the mid 130's minimum.........
Quick Reply: FM 107" kit with SE CNC Ported heads?
