Intercom with Street Glides
Is it possible to setup passenger comms on street glide special? I have the communication set-up with CB installed and it works fine. I would like to add another comm port so my passenger and I can use the intercom feature.
I couldn't find a similar thread so any help is appreciated.
This post might help.
https://www.hdforums.com/forum/new-r...-tour-pak.html
I think part of the problem is that you need the switch pack from the tour Pak because of the CAN Bus. If anyone has figured this out please correct me where I'm wrong.
The install was fairly simple using the http://www.delta-it.net/2014CB.pdf instructions. Everything works, CB communication, radio, even the intercom switches on when talking or singing to yourself. The lighted switches, although expensive for one button, look great at night. I will say though that the CB reception quality was poor with having the antenna buried next to the frame. I modified the supplied 09-13 antenna mount by drilling a new hole in the bracket to mount it to the bike which helped alot with reception. I am considering getting shorty antennas to see if the reception is still sufficient.
