Boom 1.19.0 AVC Issue
Okay, so I posted in another thread that I had issues and then fixed it by resetting. Well, it's back and I think I have figured out how to reproduce it.
Turn on your bike. Adjust the AVC up 1 tick.
Turn off the bike for 30 seconds.
Start up and go for a ride and see if AVC works.
On mine, once I go up from 2 to 3 or 4 ticks, my avc stops working. I hvae not tried going down but as soon as I set it back to 2 ticks, it works as it should after restarts.
Can anyone try this and tell me what you find if you AVC didn't work prior to 1.19.0?
Update
Well with new update I did not play with the AVC, But I just leave it all the way up cause while riding with wind noise and exhaust you need it loud anyway.
But I did notice one thing on ride today. After the 18.whatever update the usb stick would lock up. If I tried to select the artist or song or album the boom box would lock up till I turned the bike off, It was so bad that I just would not use the usb stick cause it would not work, just would listen to the radio.
But tonight after the 19...whatever update it seems the radio is a little better the usb part of the radio is working ok so far, I can switch songs artist albums and it don't freeze up, so far so good. maybe they are getting closer to having everything working ok.
