Shifter shaft seal leak
2015 RGS with 1800 miles. It leaked a bit when I got it but it stopped. Did a fluid change this spring, heated everything up and drained it. Put 28oz of Redline Shockproof and the levels looked good.
Dealer is replacing under warranty but commented that I probably put too much oil in. I had the bike upright on a lift and the oil was hot when I opened it up.
Great that it's being done under warranty but I should have pointed it out and had it repaired last year. Lesson learned.
The spec for 15 is screwed in until the O ring makes contact with the case per owners manual (P.151) same thing in the Service Manual (P.1-29). I don't recall how previous years were checked and memory is the second thing to go, so I always pull out the book to verify. I'm **** that way. Their implication was that I put TOO much oil in, causing pressure, causing the seal to fail. I say BS. At the end of the story, they're replacing it under warranty, which I'm very happy for.
Had that same leak on my'10 RK. Harley supposedly fixed the problem with a new double lip seal on newer bikes. Yours is the first on a new bike that I've heard that was leaking at the shaft. Too bad it's a $5 part that requires pulling the inter primary cover to replace, but it's under warranty so not a problem for you.
