Stage 3 on 103 v. my old 110 with a 574 cam
I now have a 2015 Road Glide, 103.
My local dealer will do stage 3 installed for about $2k.
Uses a 585 cam.
Is this worth it?
My other bike was a CVO 110, and I put a 574 cam in it.
However, I really do not know enough to know how to compare these.
I will be using VH power duals, a heavy breather, and the Harley tuner.
Uses a 585 cam.
Is this worth it?
I did the Stage 3 on mine, and it made a huge difference. I did have the heads worked too. I'm still putting miles on the bike before I dyno tune it. I'm going to take it back later in the week for that. The thing I like about it is, you don't have to gear it down to find the power band. The power seems like it is always there. In 6th gear at 60 mph, 1/4 throttle and 90 mph comes pretty quick. That's exactly what I wanted. On the interstate if I want to get around a semi quick, I can do that now, before it seemed like it took forever. I think it was worth it.
I'm pretty new to Harley with a 2014 FLHXS. I find the bike has so much available power just the way it is after a full stage 1 and proper tune. I'm sure the stage 3 will no doubt wake it up, but I have no problem getting around trucks on the highway at all and I'm not a little guy. Very interested to hear what others have to say as well.
EDIT:However, I do understand the need to downshift if you're not already rolling at higher speeds. I'd like to get all I can out of my bike as well and just trying to learn as much as I can about it.
