Kappa 62.11 with Stock and Flash
I have just ordered the Kappa speakers and want to install with the stock head unit and just the flash. My radio now is "loud" enough and I don't really need more volume, just want to clean it up a bit. Admittedly I will likely get a RF amp in the very near future but was wondering if anyone had done Kappas with the stock unit and just had the flash to eliminate the problems wtih the radio adjusting the sound.
Also, I was planning on doing the install where the speakers are inside the box rather than outside so they fit better. Is there any other way? I see people on here having to use weather stripping to seal the speaker to the inner fairing...is this a good way to install or can I get different speaker covers? I thought that the speaker was hitting the fairing so no cover will fix that, right?
I installed the 62.11i's and they are a big improvement over stock, and even when the outside perimeter of the speaker surround does touch the boom speaker gills. Doesn't appear to affect the sound at all. To make a very long story short, I installed the speakers inside the pod at first, the speaker magnet hits the pods inter ribs. Fixed that and the speakers still sounded like poop. Added weather stripping as some has said works, still junk. Mounted them on the outside of the pod, countersunk the mounting screws, added a small amount of polyfil to the bottom of the pod and they sound great. If you're not adding an amp now there is no need to flash your head unit. And the speaker surround touching the grill/fairing? I've had them installed now for a couple of months and no problem, they still sound great, clear and loud. I'd compare my current sound to the Boom II with an amp!
Oh yes it does touch the fairing at the very top too, about 1/8 inch. Evidently there is still enough surround to do it's job. I don't blame you one time is almost too much. I've had them off and on about 8 or 9 times and I am now a pro at those three bolts at the bottom of the pod. Now you want more info go to the audio section here. I think there are about 160 pages related to the install of speakers and amp for '14 & '15 bikes. And a lot of them refer to the installation of the 62.11i's and the PBR300x2. You'll learn a lot before you start your install.
Stock grills are stretchy cloth, not metal. I don't think that they will be a problem unless the plastic frames rub around the edges. At this point I have just ordered the speakers and will figure out what I need to do once I get a chance to work on it myself. Too many inconsistencies and trying to sort the posts out is more work than just doing it. If I need new grills I will just run it without until I get new ones.
I used my thumbs to flatten, but there are other ways tried... https://www.hdforums.com/forum/audio...or-kappas.html
Stock grills will NOT work...not even close.. I have the V-twin grills. Fit nice. Had to egg the mounting holes out a bit and snip some of the mesh away from where the speaker mounting screws were. I just didn't like the "CS" on the cycle sounds grills or I would of bought those. Call or Email Brian at V-twin and tell him you need the deeper recessed grills for the Kappas.
