2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
6.5 GPS speed source?
Old 05-03-2015 | 11:07 PM
FinalShot's Avatar
FinalShot
Originally Posted by 14cvoultra
Does anyone know how to keep the GPS from getting the speed sensor
signal. I would like to keep the GPS from seeing the signal.
Are you trying to circumvent the speed sensor so you can enter info while riding?
Old 05-04-2015 | 08:05 AM
MilesOfTexas's Avatar
MilesOfTexas
I think 14cvoultra may be thinking if the GPS doesn't get the signal from the speed sensor it may instead calculate speed based on satellite information, but I am not sure that's what they are trying to achieve.
Old 05-04-2015 | 11:57 AM
Kevinch's Avatar
Kevinch
Originally Posted by Bikerscum
I guess that's my point.... it would take 30 seconds to correct if you know the actual speed.
Right - but when your tires wore down, wouldn't you speedometer change & then disagree with the GPS again? And then when you bought new tires - especially if they are a different brand - wouldn't it disagree again?
I don't think you find any on-board GPS system in any vehicle displays the speed from the satellites. It will always be from the speed sensor so it agrees with the speedometer. I usually check ours against a portable Garmin to see just how far off they are & make a mental note.
Old 05-04-2015 | 03:06 PM
Bluehighways's Avatar
Bluehighways
On my Honda Goldwing they fixed this problem. The GPS does NOT display speed under any circumstances. This is good because the Speedometer is so wildly wrong. I had to buy a "SpeedoHealer". The "SpeedoHealer" goes in the VSS (Vehicle Speed Sensor) circuit and can be adjusted to make the Speedometer 100% accurate. Has anyone taken a handheld GPS on their Harley with the 6.5 to see how accurate (or inaccurate) the Speedometer really is?
Old 05-04-2015 | 03:13 PM
FinalShot's Avatar
FinalShot
Yes, I have. Here's a thread on it. Mine is pretty accurate once I adjusted the speed using my PV. What I have found is the decal on the speedometer is actually off. Since we know that the Boom GPS and speedometer are one in the same, I could map the differences using an external gps.
https://www.hdforums.com/forum/new-r...l#post13393693
Speedo / Bike GPS / Uleysee GPS
20 / 20 / 19
30 / 30 / 30
44 / 44 / 44
61 / 60 / 60
72 / 70 / 70
82,83 / 80 / 80
Old 05-04-2015 | 04:41 PM
SafetyMan's Avatar
SafetyMan
I did, and across the band to 100mph I found it to be 4% off.
I adjusted the PPU 4%, now reads dead accurate with my external Garmin.
But I work with electronic instrumentation in the oilfield for a living, and it makes sense to me.
Old 05-04-2015 | 08:13 PM
14cvoultra's Avatar
14cvoultra
Yes I am trying to circumvent the speed sensor signal to the GPS so that I can enter info while riding? But after studying the wiring diagram today I have to assume it is being sent on the canbus line could not find a speed sensor signal going to the GPS. Back to the software Hack
Old 05-04-2015 | 10:51 PM
RG Pilot's Avatar
RG Pilot
Mine is also off by 4% using a Garmin to compare it to. As soon as V&H comes out with that speedo correction update that I'm hearing about for the FP3, it'll be fixed.
Old 05-06-2015 | 12:44 PM
ShoreRider's Avatar
ShoreRider
I got the following using my GARMIN/Bike GPS/Speedo:
30/29/29
45/44/46
55/54/56
65/65 (fluttering between 64/65)/67
75/74/77
Old 05-06-2015 | 05:02 PM
Eltopia's Avatar
Eltopia
Installed Dakota Digital dash and set the speed at 96%. Now speed and mileage are accurate according to the 5 mile speedo checks on freeways. The odometer & speed were both off 4 %
Capt_Salty
11-06-2018 09:04 PM
HarleyCamper
17
09-21-2018 03:08 PM
rob0225
13
08-04-2016 07:04 PM
Duc
06-17-2014 09:45 PM
pgpn
08-10-2012 10:54 AM
Quick Reply: 6.5 GPS speed source?
