Primary noise
Run Harley's formula + in there. That is what is called for now and this applies to previous twin cams. However, think the CVO 2015 calls for SYN3 in it for some reason. Do not run too thick just to hide a little noise. What you are hearing is just the out of sync noise from Harley's uneven firing order. The cylinders fire opposite of each other but not every 360. The compensator is designed to smooth the impulses of this but their faces are not machined. So they make a little uneven noise. You only hear it at idle. Just ignore it if the man at the dealer thinks it's OK. If not, it's going to drive you nuts and when the tin men get through here, good luck doing that.
The compensator can wind up about 30 degrees in either direction. I can bang mine pretty hard if I really get on it and come off the clutch going thru the gears. Not sure how high an rpm you are coming off throttle at or how hard you are coming off but that just may be a transmission gear noise. Noises are really difficult to pin point since that can migrate through steel and aluminum. Obvious you are not going to be able to listen to it with a 2 ear stethoscope. What you describe just could be the exhaust tone. Even though you come off the throttle, the throttle by wire controller feathers the throttle body butterfly to give the engine air to burn the remaining fuel in the system to reduce exhaust pollution. This feathering give a different tune to to the pipes. (you can watch it in the tac if you kick it in neutral and let the throttle completely off)
Agree with the formula+. Noise from my primary was so noisy a dealer replaced the compensator, but the noise didn't go away. Then they put formula+ in the primary instead of syn3 and the noise is dramatically less. I only use formula+ now. I also found the clutch seems to grab better with formula+.
