2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Stage 1 and warranty issues..denied?
Old 04-21-2015, 03:34 PM
Lawdawg's Avatar
Lawdawg
Lawdawg is offline
Default Stage 1 and warranty issues..denied?
Has anyone had an issue with their bike and being denied warranty work because a stage 1 was installed?
If so what was the outcome? Would the manufacture of the fuel system help fight them?
It would seem that adding a stage 1 would only make the bike run better.
Thanks
Old 04-21-2015, 04:50 PM
RG Pilot's Avatar
RG Pilot
RG Pilot is offline
If a problem is caused by the stage 1 and can be proven, then yes you're warranty is void only if you bought an aftermarket tuner or had it dynoed. Slim to nothing chance that it would be caused by the stage 1 unless it was a bad flash by an aftermarket tuner. If you had a dealer flash, you'd be covered but they're pretty much worthless.
Old 04-21-2015, 05:54 PM
Rat Trap's Avatar
Rat Trap
Rat Trap is offline
Thanks
After reading hundreds of posts about the "warranty" being "void" after doing mods, I'm starting to think people don't under stand how it works.
If they "the dealer" can prove that your "mod" caused the damage then, yes, they can deny that claim. Your warranty isn't a "one and done" contract. Its on a claim by claim basses.
If you do a stage 1 and your transmission goes out or a wheel bearing goes bad, then you're still covered.
But, if you did that stage 1 and you burn a hole in a piston then you'll probably have to pay for that our of your own pocket, but your "warranty" for everything else is still "good".
Unless your local dealers service department is being really pissy, then all bets are off.
Old 04-21-2015, 08:05 PM
68 XLCH's Avatar
68 XLCH
68 XLCH is offline
HD dealer did the SE tune and dyno, 87.6 HP and 106. something torque. They told me this would not cause any warranty issue.
Old 04-21-2015, 08:44 PM
Harttoo's Avatar
Harttoo
Harttoo is offline
Does'nt it say on the SEPST box.For race use only.Engine warranty is void?
Warranty: Installation of Screamin’ Eagle
® products, and similar offroad
or competition products from other manufacturers, except some
street-legal offerings installed by authorized Harley
® dealers, may void
your H-D
® limited vehicle warranty. See your dealer for more information
Old 04-21-2015, 09:18 PM
Lawdawg's Avatar
Lawdawg
Lawdawg is offline
That's what I figured...they would have to prove what I did or what I used caused the problem.
Thanks
Old 04-21-2015, 10:50 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
I've had a self-installed Stage 1 on mine since I brought it home and got the wrenches out.
Just modded my air cleaner to an external breather last week.
Had warranty work done this morning....
No issues.
So, no. My warranty has not been "voided".
Old 04-21-2015, 11:41 PM
Lawdawg's Avatar
Lawdawg
Lawdawg is offline
No issues.
Awesome thanks!
Old 04-22-2015, 08:19 AM
matt76cmich's Avatar
matt76cmich
matt76cmich is offline
Well I am about to find out here real shortly. The dealer is almost here with a trailer to take it back and check the motor. They installed the Hi-Output mufflers, but I installed the Dresser Duals and added an FP3. I flashed back to the stock settings and took the FP3 off the bike. From everything I've been reading on here and how I explained it to the tech, I more than likely have a lifter issue. I have 2026 miles on the bike and hopefully this will be fixed quickly. First time dealing with a new vehicle and warranty issues.
Old 04-22-2015, 08:25 AM
Cowboy Rob's Avatar
Cowboy Rob
Cowboy Rob is offline
Big Kahuna HDF Member
Received 2,574 Likes on 1,498 Posts
When I bought and had my initial flash done with my SEPST, the dealer not only RO'd the tuner under warranty, I got it in writing and he signed it on the receipt.
Quick Reply: Stage 1 and warranty issues..denied?
