2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Best way of using the gps system
Old 05-04-2015, 01:24 PM
caberto's Avatar
caberto
caberto is offline
I've been using Basecamp gpx exported to thumb drive and can download to the nav system without any adjustments. Has always been spot on. I just make sure I add a Waypoint on every road I want to take if it's not the most direct/quickest route in Basecamp.
Old 05-04-2015, 08:22 PM
14cvoultra's Avatar
14cvoultra
14cvoultra is offline
Only select the file that you named it should be the second one in the list.
Old 05-07-2015, 08:21 PM
cybricon's Avatar
cybricon
cybricon is offline
H-D Planner works fine for me, too. Just have to connect your Garmin using the free plugin for your browser. Be careful, it only saves the waypoints, so unless you have enough waypoints to "force" it to take your desired route, it may choose a different route between waypoints than you intended. Also, when you make waypoints, be sure to zoom in on them and make sure they are on the road you intended. Sometimes they are actually on a side street, causing unnecessary turns, which is pretty annoying.
One last thing: Be aware, while riding, whether you have avoidances turned on, such as "avoid highways". Sometimes I turn it off to get somewhere fast, but forget to turn it back on. Or vise versa, sometimes I have had it on avoid highways when I really just want to get somewhere fast, and it took much longer to get there.
Old 05-08-2015, 05:46 PM
hal174's Avatar
hal174
hal174 is offline
Thank you all for your inputs. Been away from home all week, but will follow the advice above when I upload my routes from the USB stick. I think I was loading too much stuff and it looked confusing, Cheers.
Kenney
04-10-2016 07:26 AM
UltraV
10-28-2015 04:55 AM
Dark Knight
Road Trips
51
05-29-2015 07:17 AM
alandchris
01-05-2014 11:54 AM
monkey sammich
Road Trips
05-08-2012 09:41 AM
Quick Reply: Best way of using the gps system
