2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Thought This Should Not Happen
Old 04-04-2015 | 12:55 AM
FinalShot's Avatar
FinalShot
Default Thought This Should Not Happen
I was 250 miles from home, in the middle of the desert, 60 miles from a town when I felt something bouncing around my left ankle. The shifter shaft fell off, even with the bolt still install and tight.
Stopped at the next gas station, removed the bolt and slid it back and tightened it down. Is still loose and can be pulled off. The splines are not worn out. I think I'll zip tie it as a safety measures so I don't loose the whole shifter on my way home.
Old 04-04-2015 | 06:15 AM
RK_2014's Avatar
RK_2014
The same thing happened to me last summer.
Took it in and they replaced the assembly under warranty
Old 04-04-2015 | 07:05 AM
DocKile's Avatar
DocKile
Had it happen several times on my 11 Ultra, no issue yet on my 14 Ultra. Seemed to only vibrate loose on long runs. I put some blue loc-tite on it seemed to work for a while then it would vibrate loose again.
Old 04-04-2015 | 07:30 AM
dc3plt's Avatar
dc3plt
What a nice "feature".
Old 04-04-2015 | 07:32 AM
RK_2014's Avatar
RK_2014
Good idea I think I will do that but may use either red loctite or a nyloc nut
Old 04-04-2015 | 07:37 AM
CanonSterVA's Avatar
CanonSterVA
If you use red loctite, you will need to apply lots of heat the next time to pull it apart.
Worst is cleaning the threads later of the residue unless you replace everything.
Nylon loc nut or blue and check it with each oil change.
Myron
MikeyTX's Avatar
MikeyTX
Default Great Exercise
Wonderful way to loose that excess flab. Duck walking ones scoot down the shoulder of the highway. Just remember to turn on your flashers .........
Old 04-04-2015 | 07:50 AM
RK_2014's Avatar
RK_2014
Myron
Myron - good point with the red loctite and checking at oil change time
Thanks, will go with the nylon lock nut
Old 04-04-2015 | 08:21 AM
Harttoo's Avatar
Harttoo
Happened with My 2012 Limited.Had to install a lock nut .
Old 04-04-2015 | 08:29 AM
Stiggy's Avatar
Stiggy
On my old Road Glide, I still run the original shifter levers. I had to open the slots with a whiz wheel to give the bolt enough room to really clamp down the the splined shaft. The levers aren't manufactured with enough of a gap right out of the factory, IMO.
Quick Reply: Thought This Should Not Happen
