Electronic throttle twist grip sensor extension / heated grips
ok so I thought I got what I needed to put these 14" bars on the bike. I picked up a switch wire extension kit which takes care of the switches (turn signals, etc) but not the throttle or heated grips.
Before I hit the local dealer in the morning might anyone have the part numbers or know what I'm talking about before I walk in there in the morning?
I need wire harness extensions for twist throttle and heated grips wiring that run through the handlebars
Thanks
Thanks
Find the thread "apes/TBW issues" I think it was called. I listed the parts you need for the SE tbw swap over to 14-up bikes. You need to repin the wires and swap the plug over from male to female or visa versa. And you get rid of the green plug as mentioned above. My bars have some nasty bends so that green plug was screwing me over. I did extend the black and white wires tho, I believe for the heated grip, as even the SE TBW wiring for that wasn't long enough to run the whole length of my 16's.
Thanks
Don
Heated grip extension might be needed but probably not the TGS/TBW extension.
The heated grip extensions, however, are nothing more than wires with a bunch of splice connectors. You don't need to buy em; just make your own. I needed them on my 14" KST mayhems. The TGS was fine, the heated grips needed to be extended, though. It's easy to extend those.
Oh, and the CVO TGS does have the element already extended the length of the entire unit. Damned handy. Why they didn't use the CVO TGS on every model is beyond me...
Ok so here they are. I went to my local dealer and got some great advice and suggestions and that's what I did. Went out and bought a solder gun, some 18 gauge wire, and some shrink wrap. The twist grip sensor and the heated hand grips had to be extended, the switch housing units were extended by purchasing the extension kit from harley ($30), the clutch and brake had just enough for the 14" bars but I wouldn't push it any higher. We spliced, soldered, then shrink wrapped the heated grips and TGS by about 6" just to give it some extra room.
The handlebars are Khrome Werks 14" Bagger Apes and they are exactly what I've wanted.
