I am trying to connect my PV1 to my 2014 SGS with a PV2 6 pin cable and I am getting an error message can not read ECU data. Ignition and run switch is in the on position. Everything comes on as expected just wont read ECU so I can send Fuelmoto my stk.file for a new license and new tune. I also noticed that the data port on my SGS only has 5 pins and the cable is advertised as a 6 pin. Any suggestions???
I agree you might need a PV2, I wonder if trying to hook up a 6 pin cord from a PV2 to a 4 pin cord from a PV1 might be part of the problem...the other is you need to marry the unit, that you will need to pay the $199 unlock code to do.
Are you sure you have the right cable for the data port? That is - connecting to the right port on the bike. It happens.
Turned out to be a software issue. Called Fuel Moto and Brian walked me through the process. I had my new tune and license within 15 minutes of hanging up the phone. Hats off to Brian at Fuel Moto for the quick turnaround and the excellent customer service.
