Arlen Ness Big Sucker Air Filter
03-26-2015, 01:55 PM
did I misunderstand something, doesn't the stock derby cover work with this a/c?
03-26-2015, 01:59 PM
Works just fine. I put one on my 14 SG no issues.
Batman.
Let me edit mine a bit. I used the 18-442 if that helps at all. The one listed for 13 (using the stock cover) and below was clocked different and wouldn't fit the throttle body.
Reason: added info.
03-26-2015, 02:00 PM
I believe that it depends on which one you get. Arlen Ness shows one for the 2008-2014 (18-570) and another for a 2014 with OEM cover (18-442).
03-26-2015, 02:43 PM
What you are thinking of is the Derby Sucker which is different than the Big Sucker. Comes in Chrome or black, standard or stainless filter and costs $30 more than the BS.
03-26-2015, 03:01 PM
so it does appear that I ordered the wrong item. I ordered the FLT model and FLH one. At least now I know how it goes one.
Hope I can return this
03-26-2015, 07:31 PM
I was under the impression that 18-512 would work without the stock cover? Am I wromg on this?
03-26-2015, 08:05 PM
Quote:
Originally Posted by
2014streetglide
It does, along with 18-510(plain) and 18-560(black) - you only need the other kit 18-440, 18-441 or 18-442 if you want to use the stock cover.
03-26-2015, 08:43 PM
Gotcha! Thanks for clearing that up. It will work on a Streetglide as well correct?
03-26-2015, 09:09 PM
jd05flhtci
2014-2023 Touring Models
04-14-2017 09:54 PM
fat bastard 68
04-02-2013 09:16 AM
07ntrain
04-27-2010 08:02 AM
royston
03-05-2008 11:25 AM
jamminjim
Exhaust System Topics
06-20-2007 03:46 AM
