2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Looking for License Plate Relocation Kit HD
Old 03-17-2015, 04:44 AM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Moderator
Received 9,240 Likes on 3,187 Posts
Originally Posted by Felix 808
It's not plastic is it? Why is it such a POS? Does anyone have pics with it installed & the tour pak off?
Thanks guys
Here is a pic of mine, I bent mine back to give it a little laidback look
Attached Thumbnails Looking for License Plate Relocation Kit HD-1426585386579.jpg
Old 03-17-2015, 09:38 AM
Felix 808's Avatar
Felix 808
Felix 808 is offline
Yeah I was entertaining doing this. Is there enough light from the tail light to light the plate?
Originally Posted by motoXjoe
Here's one you can make yourself with a drill, hacksaw, and steel strap, one inch wide...
That's what I was planning to do is bend it back a little so not to have such a billboard airbrake.
Thanks for posting guys. I can see I'm going to have to think this thru a little more, as you may have pulled me back from the ledge
Old 03-17-2015, 12:49 PM
Brian73's Avatar
Brian73
Brian73 is offline
This is a fix I got from another member on different post. Took a little trimming of the license plate and drill 3 holes but turned out good. Drag Specialties 2030-0625 for plate mount and Drag Specialties 2010-0773 Low profile LED lens with bottom tag window
Attached Thumbnails Looking for License Plate Relocation Kit HD-fb_img_1426517200558-315x500-.jpg
Old 03-17-2015, 03:12 PM
Felix 808's Avatar
Felix 808
Looks pretty good Brian, but pricey $$$
Does anyone know if the HD versions can be mounted inverted to hang under the light? I'm thinking this & the replacement light lens from DS might look ok.
Old 03-17-2015, 09:21 PM
Dsm Limited
Moderator
The license lamp stills illuminates the plate just fine on mine. I looked at attempting to put mine in upside down as well. The stamping would have to be reworked to the point that you could make your own easier. When I get the time I'm going to attempt that instead.
Until then, what I have will suffice.
beantownhd
08-15-2019 01:25 PM
nicktown
07-14-2017 01:53 PM
Buszzbait
09-01-2016 11:30 PM
DougYITBOS
08-06-2012 08:03 PM
RandyS
01-26-2009 10:54 AM
Quick Reply: Looking for License Plate Relocation Kit HD
