2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Cell & Voice Without Helmet Mod
Old 04-01-2015, 04:40 PM
14cvoultra's Avatar
14cvoultra
14cvoultra is offline
Default Mike
Mike behind PV
Here's how I did my mike I used the mike from a Harley head set. If you use any other mike I think you will have to use a blocking cap on the mike +line because there is +5 volts on mike Jack that feeds a preamp in the Harley headset if you take a head set apart you will see a small board that is in line with the mike that is the amp. I pluged the mike into plug under the fairing called 280 I did not buy the extra $70 cable Just ran 2 small wires and used crimp slip connectors. Works great for voice commands and CB I only use it for the voice commands
Mike behind PV
  #32
Old 04-10-2015, 05:55 PM
MasterMac's Avatar
MasterMac
MasterMac is offline
Originally Posted by 14cvoultra
Mike behind PV
Mike behind PV
So Mike - you connected your headset 'without' using the $70 cable behind the fairing? Would you be more specific on exactly how you did that?
TIA
  #33
Old 04-10-2015, 06:43 PM
Howler_LI's Avatar
Howler_LI
Howler_LI is offline
Where can I get the grey connector shown, as used in the HD 69200865 kit?
  #34
Old 04-10-2015, 09:45 PM
FinalShot's Avatar
FinalShot
FinalShot is offline
TIA
No, you don't have to use the connector, you can splice right in to the mic wires if you want. I don't have the the wiring diagrams in front of me. If he doesn't answer, I'll go grab it and give you the wire colors you need.
You want just the connector? There are a couple guys on ebay that sell just the molex plugs.
  #35
Old 04-11-2015, 06:22 AM
Howler_LI's Avatar
Howler_LI
Yes, I just want the connector. But I don't know the lingo, what's the exact name or part # ?
  #36
Old 04-11-2015, 05:43 PM
coriobay's Avatar
coriobay
coriobay is offline
This is probably a pain but a picture of the mic connection to the 280 plug without the $70 cable would be appreciated.
I seen to many movies to cut the red wire and up she blows
  #37
Old 04-11-2015, 06:36 PM
Howler_LI's Avatar
Howler_LI
I think I figured it out. Female molex (outer) connector shells holds 12 male pins, the male shell has 12 sockets. Nice.
So I ordered from brussellex on ebay:
1 Harley 12X GRAY MALE OEM Molex MX150 connector + terminals switch wiring 07 up
Item price $9.95
Quantity 1
Item number 250913576035
If it all works out, as the Terminator said, I'll be back.
  #38
Old 04-16-2015, 09:37 PM
14cvoultra's Avatar
14cvoultra
Sorry I did not see the ? Yes I wired just the mike from a harley headset
with out the $70 cable. I used very small red crimp on female spade connectors on the wires and then just slipped them on the correct pins in the 280 plug inside the fairing.
My name is Chuck not Mike I think thats why i missed it
  #39
Old 04-19-2015, 05:34 PM
Howler_LI's Avatar
Howler_LI
This is the correct connector. The wires from my cheapo mic are way too small for me to crimp into the Molex socket terminals. I'll have to figure out how to proceed.
Item price $9.95
Quantity 1
  #40
Old 04-19-2015, 06:02 PM
pkwett94's Avatar
pkwett94
pkwett94 is offline
If you have enough wire simply strip off extra coating and double the wire back over itself.
Quick Reply: Cell & Voice Without Helmet Mod
