Rinehart Exhaust with V&H Fuelpak FP3 anyone?
Will the V&H Fuelpak FP3 bring canned maps for a full Rinehart Exhaust System? I downloaded the V&H FP3 App and it doesnt have Rinehart as an option on the exhaust combos.
What tuner are You using for your 2014 / 2015 Street Glide with Rinehart headers and slip ons?
If further explanation of how this works, please contact Customer Service at 1-800-592-2529 or send an email through the FP3 application. Below is a list of the tables that the FP3 controls.
Air/Fuel:
front/rear VE,
AFR,
throttle progressivity (primary and secondary)
Throttle table switchover gear
Acceleration,
Deceleration,
F/R charge dilution,
Closed loop range,
closed loop activation temp,
closed loop deactivation temp,
Map load normalization,
intake valve opening/closing angles,
Adaptive control min temp
Spark:
F/R spark,
spark vs. engine temp, spark vs. air temp,
spark vs. head temp,
adaptive knock retard,
max knock retard,
knock control activation temp,
knock control deactivation temp,
idle spark gain,
idle spark max,
F/R closed throttle spark,
Closed throttle spark max tps.
Performance mode:
PE afr,
PE spark,
PE disable rpm,
PE enable RPM,
PE disable TPS,
PE enable TPS,
Startup/Idle:
cranking fuel,
warmup enrichment,
iac crank steps vs. temp,
iac crank to run,
iac warmup,
idle rpm.
Active exhaust
First gear
Second gear
Third gear
Fourth gear
General:
Rev limit,
injector size,
MPG adjustment,
engine displacement,
Gear ratios (first, second, third, fourth, fifth, sixth)
System switches:
ACR,
Jiffy stand,
active intake,
active exhaust.
