2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Cobra Power Port duals, better than decatted stock pipe
Old 02-25-2015 | 11:23 AM
RK14SGS's Avatar
RK14SGS
Originally Posted by 68beep
I am running the power port along with klockwerks super savers. Easy install, uses the stock mounting point for the full sized cross over pipe and looks nice too.
Thanks. Did you notice any difference in low end torque, power, throttle response?
Old 02-25-2015 | 02:04 PM
68beep's Avatar
68beep
I put on the exhaust, free flow air cleaner and the Vance & Hines FP3 at the same time and it woke the bike up (seat of the pants dyno). It would've been nice if I'd dyno'd it but I was too anxious just to ride it after the mods. Added luxury was that it significantly reduced the heat felt by me on the right side of the bike.
Old 02-25-2015 | 02:30 PM
NWGlide's Avatar
NWGlide
Originally Posted by r0de_runr
I have had them on two bikes,, a '13 RGU amd a 12 CVO SG.
Do they utilize a spacer for the r/h floorboard? My V&H Powerduals do and I scrape that floorboard a lot now.
Old 02-25-2015 | 02:39 PM
r0de_runr's Avatar
r0de_runr
Yes they do, a thin washer and a thicker, perhaps 1/4 inch spacer.
Old 02-25-2015 | 10:57 PM
RK14SGS's Avatar
RK14SGS
Installed tonight, too late to fire it up.
Old 02-26-2015 | 12:46 PM
NWGlide's Avatar
NWGlide
[QUOTE=RK14SGS;13747115]
Your bike and Tc hunter's bike look fantastic with those pipes.
Old 02-26-2015 | 03:44 PM
OldPhat's Avatar
OldPhat
I was looking at the Cobra Power Port Duals, but went with Rinhart Slimline Duals instead.
Any pipes that have a cross over between the pipes will preform better than true duals, the
cross over helps with torque & power at the low end.
Old 02-26-2015 | 09:46 PM
TcHunter's Avatar
TcHunter
The Cobra Power Ports are not true duals, they use what they call a H connector ( H pipe ), you will not get as much torque as using a cross over but more then stock,
You will not get as much sound as true duals but deeper then stock, so you get a little of both, instead of one or the other.
Idahokid (08-19-2017)
Old 05-05-2015 | 11:32 PM
RATCHET666's Avatar
RATCHET666
Stage I
68Beep......I see your using the FP3, did you have to choose a setup close to your cobra - muffler combo? If so, which one? I'm putting the Cobra power port, 4 inch rineharts with the bigger diameter baffle on my 14SGS. Just wondering where you started with the FP3. Thanx.
Old 05-06-2015 | 04:06 AM
mdanehart's Avatar
mdanehart
I also installed the Cobra Power Ports last year along with the Screamin Eagle Street Cannons, A/C and PowerVision 2, no issues or problems. The installation was straight forward ..
Quick Reply: Cobra Power Port duals, better than decatted stock pipe
