High Idle on 15 limited
This happened to me yesterday but I could calm the idle by rolling the throttle forward. However, it would jump up again when released. I tore it all apart, didn't find anything binding or out of place, put it back together and it worked fine. Still a little stumped. If the situation you guys mentioned above is the case (shutting down when at partial throttle) would rolling the throttle forward cure it temporarily?
Not really sure why you would take the grip area apart, when normally if there is any type of binding, you can feel it in the grip and this is usually due to changing something in the area. The problem a lot of the time is found to be the clamp is pulled just a little taut, and fixed by backing off the clamp and relieving the tension on the grip. This is normally felt when twisting the throttle or when releasing the throttle and it holds that rpm longer or just takes longer than normal to idle. So, I don't really see the benefit of the "temporary fix" of rolling the throttle forward, since you would know of this high idle problem when you started your bike, so at this time, why not just reset the idle, it takes maybe a couple of minutes. This way you also know if it is because of shutting down the bike with it above idle, or if you had other issues, at the earliest time.
The high idle like the OP and others had is, as you know, caused by having the grip at a position other than the rest position when you turn off the bike. The computer uses this position as it's reference point, so when you have it turned even slightly, then it will be off and will stay at this new reference until it is fixed. I guess I am not understanding the benefit (if it works or not) of twisting the grip forward (which also affects the EITMS) since it has to be reset, or it will always idle high.
