Amps Rockford Fosgate
#61
#62
#63
It sits on the bracket just fine. There are flat surfaces on the bracket to stick the velcro (again, get the 10 pound heavy duty stuff). The velcro is thick enough to raise the amp above the edges of the bracket. I did have to trim one velcro strip around a screw head just slightly is all.
#64
#65
Oops! Figured you had a 14+ since this thread is in the Rushmore section. You can stick it directly on the head unit on yours.
#66
Looks like a rat built a nest on that thing or someone spilled their Ramen noodles next to that amp.
#69
LOL! Yeah that's the work of a F'n mouse from last fall. Chewed on the GPS antenna wire and the voltmeter wiring. Beyond pissed, but what ya gonna do.. Good thing I put the bikes in the back shed for the winter or it would of been much worse! I think he/she went for a couple rides with me last year!
#70
def do not go with the mm651
go with the infinity kappas & the pbr & the magic box. i am very happy with this set up. again not going to win audio competitions but alot better than stock and did not cost me much
installing is very easy just take your time. the biggest pain is getting the pods out. i set my speakers inside of the pods instead of outside the pods so i did not have to get the boom grills.
if you need any help let me know.
Anyway, on to the rest tomorrow. Question - what do I do with the remote power for the amp? I know I'll run the hot from the battery and the ground, but I'm unsure about the remote power.
Also, on the amp itself - where should I set the frequency and the 3 position switch (LP AP HP)? I'm assuming AP. Then does it matter where the dial is set for frequency?
Thanks again for all the help.
Did I mention how much it sucked to remove the pods?
