2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
2014 FLHTCU License Plate relocation
Old 02-08-2015 | 10:51 AM
Bam15012's Avatar
Bam15012
Originally Posted by dgreen1069
I'm guessing that kit doesn't require the use of the license plate trim plate does it? I noticed it covers a significant portion of the state across the top. No sense in giving anyone a reason to pull you over.
Dgreen, I agree with you about the 3M connecters, I just wanted to get in a ride before it snows again. Once my Laid back LED HD taillight arrives, I will do the final electrical clean-up. When needed I generally us the GM style Weather Pack connecters. They are similar to HD connection only larger. I like to use solder and shrink tubing because is occupies very little space and looks the most professional to me.
The kit uses the backing plate in conjunction with the LED trim plate. The license plate is sandwiched between the two. I guess I never gave obscuring the state text any thought. I've been running variants of this plate kit for well over 100,000 miles. Six years of the 100,000 miles were in club colors, make me more of a profiling target. I have never been pulled over on a motorcycle in almost 12 years.
Bam
Old 02-08-2015 | 12:06 PM
dgreen1069's Avatar
dgreen1069
Bam
I'd say you must be doing something right then! I wouldn't change a thing
Old 02-08-2015 | 09:20 PM
motoXjoe's Avatar
motoXjoe
I did the no hole method. Took an hour. LED corner lights for $10.
Old 02-09-2015 | 03:26 PM
Bam15012's Avatar
Bam15012
That looks clean too and I did contemplate that idea. I am just particular and want what I want. lol
Are you going to replace your taillight with one that doesn't have them clear window?
Old 02-10-2015 | 10:32 PM
jayhawkclint's Avatar
jayhawkclint
I used the same plate frame as Bam, except if you remove the factory LED fender light you can mount the curved frame without drilling any holes. I put a writeup here:
https://www.hdforums.com/forum/new-r...l#post13357545
Old 02-11-2015 | 12:08 AM
Bam15012's Avatar
Bam15012
Jayhawkclint,
Your post are what made me pick the plate mount we used.
Old 02-11-2015 | 08:26 PM
jayhawkclint
Jayhawkclint,
I agree with you that once you do the frame, it needs the layback brake light. This thread reminds me I still need to order one before riding weather gets here. Square back just looks out of place now.
For the folks just looking to ditch the clear window from the lens, pick up a later model Road King lens from the swap meet. Should run you $10 to $15 tops.
Old 02-12-2015 | 12:23 AM
Bam15012's Avatar
Bam15012
I just tracked the light I ordered from Kutter H.D. I'll have it no later that friday.
Bam
Old 02-12-2015 | 06:30 PM
Bam15012's Avatar
Bam15012
Default Cleaned-up the wiring and installed new taillight.
Rear fender profile with laid-back plate and stock taillight.
How I wired the Plate mount light prior to the LED taillight.
Removed 3M wire taps exposing cut wire insulation. I will cut and extend the wire at this point. I pulled the plug and wires out of the taillight assemble and under the fender tip light to do all the soldering.
Solder the negatives together then shirk tube.
Solder the red positive Kury wire to the blue positiveH.D. wire and shrink tube.
Stock plug with Kury wires soldered and shrink tubed. Much neater than 3M wire taps.
New taillight and fender tip/ license plate frame plugged in.
Rear fender profile with laid-back plate and LED laid-back taillight.
DONE!
Old 02-12-2015 | 06:49 PM
7125's Avatar
7125
DONE!
looks great where did you get center tail light that matches the saddle bag ligths
thanks
Quick Reply: 2014 FLHTCU License Plate relocation
