'15 Ultra Headlight adjustment
A lot of my days start out in the dark. I would like to adjust the low beam up a bit but I'm having trouble. I have the LED headlight and spots, the service manual says to use a 5/32" ball-end allen to engage the adjusting screws. I have tried but cannot locate anything that the 5/32" allen will engage. I then tried a phillips screwdriver and same problem. Can't really see in there to find out what's going on. Any one else have this problem?
Thanks in advance.
Thanks in advance.
Get a phillips screwdriver and loosen the screw dead center under the headlight, turn the trim ring 5° left, remove trim ring.
Now you can see the adjusters... and the damage you've done to your gasket.
Ride it at night with the trim ring off, take your 5/32 allen with you, and stop and adjust on the fly.
It is literally less than 10 seconds to remove the trim ring.....
