2014 Street Glide with new Gloss black trim ring with haymaker headlamp
So today I got into the garage from all the snow!
Loosened stock ring and slipped new gloss ring on tightened both and the attached pic is what I ended up with.
It just seems like a big gap at bottom where screw is located?
Is this gap correct after install?
While holding the outer trim ring together and in place with your left hand, take a small pocket screw driver and tighten the inner ring through the gap. Then tighten the outer ring a little more.....then tighten the inner ring as much as you can through the gap and finally tighten up the outer trim ring.
It should close completely with a little patience, it's all about seating the rear lip into that groove.
Good luck!
Ok I will try that.
Thank you!
Thank you!
It will tighten up completely. After loosening the stock ring, pull it forward toward you to allow as much space in the gap that the rear lip of the trim ring sits in. Position the new trim ring over the stock ring and seat the rear lip of the new trim ring into the same groove the rear of the stock ring sits in.
Good luck!
Good luck!
Not really, I took black ring off and stock chrome ring underneath to measure how much it could possibly close and I am very disappointed with HD quality it should be a seamless ring and close completely I guess am expecting too much
Thanks for remembering.
Ride Safe!
Ride Safe!
