Can anyone tell me what tool they used to align the ignition switch when you take it out and put it back in ? I had a tool for the 2013 and older but the new ignitions are different. Can you take the lower panel off without removing the ignition switch ? I'd like to adjust my bars. Thanks
14-15s DO NOT need to remove the ignition switch to adjust bars. Switch cover plate is notched, remove screws and pull it back towards tank. Then you can access the 2 lower bolts on the clamp and adjust bars.
