The POS boom that I had has a piggy back terminal that plugs into the back of the power port (cigarette lighter) then you plug the harness onto that terminal. The J&M that I am asking about is made just for the Rushmore models.
That would be pretty handy. I rarely ever listen to the radio, but it'd be nice to have it at least functional if I ever wanted to.
Do all these hidden antennas require a 12v power supply to work like the HD model? Id like to get something for my SGS since I completely removed the factory antenna and wire, but I used the one P&A harness plug behind my gauges as the remote power for the Rockford amp i installed, so without some more wiring screwing around, I don't have an immediately available accessible accessory plug for a hidden antenna.
The J&M internal FM antenna for the Rushmore bikes is completely passive. No power required.
Did you just say the J&M internal antenna works better than the stock antenna?
My stock antenna works good, I want to get a longer one.
Yes, in my case both the CB and the FM work better than stock. I believe it has a lot to do with eliminating all of the extra 5 feet of wire and connections under the seat and in the tour-pak.
I think the area where you live can have an effect on reception too, so which antenna works best might change.
Based on your recommendation I think I will give this a go. Like I said I have a USB flash drive loaded up with over 500 songs. And ALOT more room for more.
Can the HD OE whip antenna be completely removed on the Rushmore models? I was checking my service manual and it says to disconnect at the radio and the bracket in the rear and cut it. I found that odd so called my nearest dealer who suggested I roll it and zip tie it on both ends. Anyone have a solid answer on removing bc I have a bad dad rear end I'm installing once it's painted and there is no spot for a whip so I have the JM hidden version.
I installed th J&M hidden and just unplugged the stock one at the radio end - at the other end I just removed the post from the TP, tucked the wires under the liner so the cable is still there, just not connected to anything.
I did exactly the same thing. Just unplug at the radio end. Unbolt from the inside of the tourpak and pull the antenna mount inside the pak. Then use a plastic hole plug to finish it off outside.
The JM internal actually works better than the stock antenna. No 12v required.
