Nitrofill Nitrgen Tire Inflation. Anyone done this on their FLHXS?
#31
WHAAAAAAAATTTTT????? Am I actually reading about Harley riders quibbling about $10 worth of N2 in their tires after they've spent $95.95 on not-made-in-USA chromed plastic bling that costs the manufacturer $5.00??? Tell me this ain't so, Joe!!! LOL. Hey if $10 makes you feel extra good about your Harley, it's chump change well spent.
#32
The reason for nitrogen in tires is its dryer than air which makes the tire pressure more stable over all heat ranges. water expands at uncontrollable rates. So in a race car wher a 1/2 psi can really change the handling of a car at high temps, it's important. NASCAR teams also use nitrogen dryers, to get even more water out. Your tire is just a spring so changing tire psi is like changing a shock spring. Just keep your tires properly inflated and air will be just as good for most Applications.
As others have pointed out, "so what"? If the pressure stability is worth it to you, use the N2. Its relatively cheap and available. I've got a $25 electric compressor in my garage suitable for adjusting air pressures so use that and carry on. Whatever floats your boat but FWIW yarns attributing magical properties to the N2 molecule are bullshit, pure and simple.
#33
I have been using Nitrogen since 2009. It seems to do everything as advertised.
In the Midwest my tires pressure is stable through winter storage. Last spring first pressure check from my first ride after storage showed the same readings as before winter storage.
The cost is low so I can't see any reason not to go with it.
#34
By the way I went to the local Acura dealer so I could "Just Do It" on Saturday morning. I'll let you guys know if it works the same in a motorcycle tire after I ride a couple of weeks.
#35
Originally Posted by [B
Mozvader[/B];13756175]Facts and scientific data are all fine and dandy but the stuff works in real life applications.
Mozvader[/B];13758170]I started the thread because I wasn't sure if loss of pressure was an inherite flaw of motorcycle tire design. I usually top my tires off every few weeks and there is always about a 3 or 4 psi loss. The local dealer doesn't offer Nitrofill so I was curious if anyone had already tried it in their bike and what results they got.
#36
Nitrgen or not
some how I am confused. I read that nitrogen is good for the rubber and that air out of the compressor tends to dry out the rubber thus making less effective. I wonder since I live in Ohio and my motorcycle will be off the streets for a month or two. I would think that nitrogen would be a positive tire component. I'm not sure if my dealer offers the Nitrogen at a price yet for the bike and dealer are new to me. Is there a place one can get it free in the Dayton, Ohio area?
#37
Nitrogen is cheap and available and if using it appeals to you then by all means use it. As a matter of interest though, just know that what benefit you do derive from it is a result of its coming to you via a gas plant which produces, drys, filters, puts into HP bottles, tests and certifies the product before delivering it to their customer (garage). Compare this to garage air from a basic LP compressor, which just takes atmospheric air, including its "high" moisture content , possibly introduces some oil vapor, and blows this into your tire; now you've got the picture. Air coming from the same gas plants as nitrogen does, (diving air), would behave just exactly like nitrogen does in your tires.
#38
Ok so its been a week and I've ridden 178 miles. Just checked my tires and I haven't lost any pressure. Still in testing phase though. If they aren't 2 - 4 pounds lower by next Friday I'm calling the experiment a success.
I'm not a believer in Nitro improving gas mileage or anything else other than just lessening maintenance. Thats all I'm looking for guys. It works great in my car...
#39
So the bottom line is, Nitrogen in motorcycle tires only stays in the tire slightly longer than compressed air. It appears that the checking the pressure regularly and topping it off when needed makes compressor air equally affective. Then, the deterioration of the rubber is really not a measurable factor for the average motorcycle.
