Tour Pak
You will need a barrel lock, either key matched or its own key ( rider preference )
You will need the two screws to mount the barrel lock........yes those are separate.
Backrest of your choice, should come with mounting hardware. For what its worth I went with the CVO street glide backrest keeps the sport look........ I have been told. Kutter Harley had the best price at my time of purchase.
The plate does come with the hardware........Kutter best price
Most importantly some kind of cam lock or a lock so no one stills your pak.
Pak liner or any other pak goodies, if you choose.
It sounds like you have the important stuff tho.
If I may add, if you are still shopping around for your pak try Manchester Harley super store, by far the best price I have found.
Yes, it took 4 weeks for delivery not bad.
It was packed fine, basic foam wrap around the tour pack, then thick foam blocks on each corner.
No issues with scratches, scuffs or any other damage.
It came with the hardware for the plate which the plate also came with hardware.
The two hinges and handle already put together and the built in tether for the lid and the bottom rubber mat.
I would defiantly order from Manchester again.
Both, HD brand and there is after market.I hear a lot of people complain about the HD one.
~ Clamp it security Jr locking system.
~ Brukus tourpack bullet secure.
I hope this helps.
How much for shipping? Thank you.
AK BAGGER
12-11-2010 12:14 PM
tcfamy
07-13-2006 07:18 PM
