Last edit by: IB Advertising
What oil is the Best?
Any Quality 20/50 oil will do with a change every 3000 or so. Read more at:Oil
Read Full Discussion below
What Oil Is The BEST
#81
Tell me what oil isn't a quality oil. People give advice to use any quality oil? What oils sold are not a good quality. Can some one tell me about an oil related failure because they didn't use amsoil? Just wunderin. I Used amsoil, Mobil one, Specto and redline. I am currently using Valvoline motorcycel oil I got it deliverd to my door for about $6 a quart and it seems to work good for the the first 4000 miles. I am going to change oil soon and think I'll use Mobil one since I have 4 quarts in garage. I really believe it don't matter. Ride on people
Hap
Hap
That's the only way to know what is what.
I have a good friend that is **** about doing his, so I do know what is better.
To answer your question, no, I have never had an oil related failure.
....but everything else being equal, wouldn't you want to run the best?
#83
I've done a lot of reading on this subject. There are pretty much as many different opinions, as there are types of oils. That being said I still wonder, if I would hurt the engine of my Harley, if I use regular 20W-50 automotive oil for the break in before I switch to synthetic. A Harley motor is not considered a high-revving, high-output racing machine. Any small four-cylinder car engine can rev higher and put more horses out than a stock Harley motor. Sure, they are water cooled and not air, like the Harleys, but I don't think it does not matter, or does it? What's your take on this?
#84
I prefer Mobil1 in the crankcase, Mobil1 GL5 gear oil in the tranny, and HD Formula+ in the primary. I used to use Syn3 in all three but on my 14 Limited if I don't use the Formula+ in the primary, the primary is noisy as hell. So noisy that the HD dealer in Colorado Springs replaced the compensator with only a few thousand miles on the bike. The GL5 gear oil also quiets down the transmission gear lash.
#85
#86
I've spent the best part of an hour searching through the antiquated search features of this forum for a simple answer to what grade oil goes in which hole because I don't believe for one minute that HD make oil and I don't want to pay for a third party manufacturer relabeled stuff.
This was the first relevant thread I could find and it's full of idiots going on like being a forum veteran is some sort of badge of honour that makes them heroes in the world.
Thanks to those who tried to answer a simple question from the OP legitimately because it's easier to find the meaning of life than the oil grades for a HD.
#88
O Rings too!
My HD dealer charges $1 each, but you can get a pack of 10 for just over $2 at Home Depot (the other HD). Danco #8 Home Depot p.n. 96725.
I use Mobil1 20W50 in crankcase and primary, Redline Shockproof in tranny as I always have done. I also like K&N oil filters due to the ease of removal. K&N KN-171C.
Another useful tip is to get rid of those damn Torx bolts on the primary and get some nice chrome allens 1/4-20 x 5/8. If you dont have a local stocking HW store for chrome bolts and washers, I use Bolt Depot.
Now to be sure the beer, wings, chips, and firewood is in place to watch the Patriots kick some Seahawk ***.
Bob
#89
I do a lot of reading on other non-Harley forums regarding oils. Some of these guys get oil analysis done -
One thing that is common among many oils even the synthetics is that in as little as 2000 miles the viscosity rating is half of what it was originally ie: 50 weight oil only measure out to 25 weight. Shear ratings also suffer which would lead you to wonder about the lubrication protection.
#90
